Hello all,
I think the TOPS is bad on 06 RXP I am working on as I get a 10 ohm reading in UP position and no reading when Inverted - which are incorrect readings per shop manual. I did not get a P- code fault showing on Inst panel and do not have a BUDS or Candoo system to verify.
Based on readings I take it that the TOPS circuit can still fail w/o showing a code on inst panel?
My understanding of TOPS circuit is that this would also keep the RXP from starting normally until replaced??
Allows motor to turn over but not start is this correct?
I went thru shop manual and the boards trying to find any additional info on circuitry other than shutoff of oil system.
Secondly I am trying to ID the correct connector type for two areas:
(a) What is the connector type for the TOPS connector in the bow? - I know its 3 pin small flat blade type and think it is a Deutsch but could not find a marking on the case... want to build separate T/S connector - I improvised making one for the connector today at the lake for testing system.
(b) what type connector is on the ignition coils? The owner lost the gasket seal on IGN circut #3 when he replaced the spark plug and wanted to know if I could order a replacement for him.
I could not find a match online ..but thought it was close to a Deutsch DT series connector...
Unfortunately I forgot to take photos of the connectors - and the PWC is at a lake 40 mins from my house.
Any assistance would be greatly appreciated ...
thank you for your time ...
