Brprxt215
So I posted a week or two ago about fluctuating rpm and only 40mph at 6800rpm. Since then I have put in OEM rectifier, new wear ring and pulled the fuel neck off drained old fuel and put fresh in(unsure state of original fuel). Took to dealer and had BUDS hooked up. Only code was multiple 12v low which I’m assuming is from old aftermarket rectifier. Went to water test and could not even get it to run 40mph or 6800rpm before it stalled out. Would start right back up every time and run at idle as long as I wanted. I built a fuel pressure gauge yesterday and tested.(
) videos of test while under load at boat ramp . One thing to note is after shutting off it leaks pressure and drops to about 20psi after about 10 mins. I was reading it should sustain pressure for a long while. Does this sound more like fuel pump or fuel regulator problem? Anywhere else the pressure could escape from?
