rx di loss of power
Robianley
Any ideas here?
RXDi lost power after about half of use, very noisy in driveshaft. No warning messages appeared on the gauges. It's just had a service.
Will be taking it to dealer on monday!
What do you mean lost power?
Is it reving but your not going forward like a slipping clutch or wheel spin in a car?
Or wont rev bogs down when you gas it?
RXDi loss of power
Problem is more like clutch / driveshaft . No problems with motor power and revs. Just hoping its not any thing major and expensive! It has just had a service which included jet pump being serviced.
thanks for any advice you can give me
Sounds like its in the jet pump area. Did it do it as soon as you put it in the water? If not you may have sucked up debris. Or the prop may have come loose? :(
Thanks 12 nvy
You were right, I did get debris caught in the jet unit, it lodged in the prop
it looks like minimal damage but will know more tomorrow
thanks for your help
