buckeye_paul
I know I'm going to get some useless information for putting this out there but here it goes. Has anyone ever asked a Mercury technician if it is acceptable to run on the hose? I don't believe it is.
Here's why.
The first time I ever ran this motor on the hose, it ran about 4-5 minutes then I got the overheat alarm. From then on and until today, every time I've ran on the hose, I ran it for less than a minute just to check that it would start okay before heading off to the ramp. Today while working on a project I let it run for about 4-5 minutes and got the overheat alarm again. I have never had an overheat while out having fun and the tell tale has water running from it. While on the hose there is never water coming from the tell tale.
Here's my thinking. This is an open loop system and needs pressure to operate properly. Water can't fill the loop due to gravity. The water is following the path of least resistance and is pretty much running out the bottom without filling all of the water passages around the cylinders. While the boat is in the water, the impeller acts as the water pump. This pump fills and pressurizes the system, thus the water from the tell tale.
I'm betting a Mercury technician that works on Sport Jets, has some kind of rig that goes under the boat and allows the water to be pumped up into the motor. I have a smaller boat with an outboard motor and I can run it on the hose indefinitely. Anyway, tell me what you think.
Here's why.
