I plan to run the engine on my 1996 XP while it is out of the water on the trailer. I have the hose connector adapter and hose shut-off tool for the discharge hose. Is the water running from the hose only for engine/exhast cooling or does it lubricate the impeller as well? If it does not lubricate the impeller assembly, how long could you run the engine without any water from a hose attached? I know the manual procedure attaching the hose and pinching off the discharge hose is only for flushing the system. I would like to run the engine for a few minutes without any water attached if it is not harmful while I check adjustments.
Anyone have any experience?
Thank you.
Thank you.
