the427king
I Have a 2003 sea doo 4 tec sportster. It was running fine last season. I had it winterized and serviced last winter. The first time I went to use it I started it out of the water just to make sure it would run . It took a few more push on the start button than other years, and when it started up it went to an extremely high idle. I shut it down immediately and then tried it again with a hose hooked up to it. Same result. It never ran more than a few seconds. I put the boat in the water and upon starting there was alot of bubbling around the boat and it spun slowly around in a circle in neutral. I shit it down and pulled it out of the water. Cable appears fine although im not sure how taught the cable should be when in the off position. Could the person that serviced it left a plug out that is causing an air leak??? Thanks in advance for any help
