Unclebilly
I don't want to drill through my transom.
I am considering running my transducer wire through one of the deck drain through hulls but with a twist.
What I am considering doing is putting a TEE in the hose in the engine compartment. The side port on the TEE would use a reducing bushing to a watertight bulkhead fitting for wiring with conduit - this is where the transducer wire would exit. Further toward the cockpit, I would put in one of those generic deck drain ball check valves. The valve would prevent outside water flowing in like the factory ball check does and I can seal off the transducer wire without adding another hole in my hull.
Any concerns or reasons that this idea sucks?
