Chr1sfrench
Ok here is my problem im rebuilding a 787 from the ground up and i can not get it to turn over with the plugs in. It cranks easy by hand and easily with no plugs in. I know its not hydro locked bc i just put a new crank in. the motor is currently sitting in the hull not connected to the drive shaft so that can not be binding. i know its not the starter selonoid bc i already swapped it with another one. no change. I have also tried 3 different starters that all work on my other seadoos. No change. also tried 3 different batteries. I thought maybe my head was milled so i swapped with another head and still no change. I eliminated it being and bad wired like a bad ground or bad power cable by trying to jump the starter directing to a NON running car battery and it still wont crank. Cylinders are good. Pistons are good. Piston rings are good. lower end is good.
The only thing i can possibly think of is too much squish and i have too much compression. i have a number 5 gasket on now. When i check my compression im getting 160 in both cylinders. ill add some pictures of my set up.
