Riverguy42
Hi, I'm a 50-year powerboat veteran and generally considered competent with inboard/outboard/diesel/gas/2-strokes/4-strokes etc., but I have never seen a Rotax before.
Like many 2-stroke Rotax noobs, I asked myself the question "why should I rely on a possibly failure prone injection pump system, when I can just put oil into the gas tank and be SURE the engine is getting enough oil?"
It took me a little while to understand what I THINK is the answer. Please forgive me if this has already been discussed, I looked but could not find anything.
If I am correct, then bypassing the oil-injection system in a Rotax would eventually destroy the engine.
Here is my assessment, please correct me if I am wrong:
Looking forward to comments, and to learning more about this!
- Rotax engines are designed to inhale an OIL/AIR MIXTURE into the crankcase.
- This ensures that the rotary valve gets lubricated (because that's where the oil/air mixture gets into the engine).
- It also splash-lubes everything in the crankcase with pure oil instead of oil that's diluted with gasoline.
- Bypassing the oil injection system and putting oil into the gasoline instead defeats this entire design.
