matt79
Hi, I have recently purchased a 97 HX and it's great. A friend of mine has the same one which he bought cheap as it had a blown bigend. He has recently rebuilt the engine and after taking it for it's first run, the brand new 14 tooth helical gear that drives the rotary valve had completely stripped after 10 mins of running in. His ski has had the oil injection removed as opposed to mine and after some brainstorming, we have realised that the 14 tooth gear has no lubrication. Am I right in saying that this gear is usually lubricated by the oil pump and if the ski is modded to run premixed fuel, the part of the crankcase housing the gear needs to either be filled with oil or run and external reservoir and still use the pump? please help. thanks
