jmartin915
For those who did not read last threads...timing was off and backfiring (slightly), mechanic told me it was the rotary valve gear on the crank shaft...ended up not being it. Here goes with the rest of the story...I got back from Chicago yesterday but parts had not arrived to reassembly the motor (gasket, I damaged the gen. coil and light. coil and the temp sens was bad). Hopefully they'll be here tom. While the motor is out I am installing new fuel lines (black) and discarded the gray. Will post more when I get parts to keep you all updated.
