My ride plate is not fully sealed. I believe this is why I have a slow hole shot, where the boat hits max RPM but doesn't gain a lot of speed, then the RPMs drop some and the boat picks up speed and RPMs. I have no trouble reaching max speed or RPMs. I'm looking for tips on sealing the ride plaate (what's the preferred material, anything special with the procedure, what else should I do at the same time, etc.). Also, I assume I should seal the entire perimeter? Finally, does the same go for the pump shaft? Photos attached.
