I have a couple of Seadoo RFIs that have problems with idle, acceleration and such. I've worked on a few RFIs and beyond the simple I'm wondering if there are any common WIRING issues on these skis. I've tested components 2 and 3 times on these skis, swapped parts.... I mean ALL the parts and the skis still have the same bogging type problems. At present I'm leaning to a wiring harness issue, bad switches or DESS posts. I'll lkely be pulling pins and connectors to have a look.
Just a list of what I have done and I follow this procedure on all the RFIs.
1 test - TPS, Air Pressure Sensor, Air Temperature Sensor, Crank pick up sensor, Rave solenoid, rave valves, check valve to the rave solenoid, fuel pressure pump and regulator, replace filters, rebuild fuel injectors. Test all components at the #4 plug. Check Grounds, check the mag coils, check/replace the rectifier, good battery, compression, Disconnect all gauges up front. Disconnect the Trim module, check fuses. I've swapped out, whole computer both boxes, TPS, Air pressure Sensor, Crank pick, coil and complete throttle body at one point. Pulled the exhaust hose and inspected. Skis still bog... really sound like they are not getting fuel but the obviously are.
To me, it has to be a harness or wire/plug issue but this is on more than one ski. I'm gonna check out the start/stop switch and DESS. I'm not bitching... this is an adventure. I'm gonna find it. LOL Help/input is appreciated. Weird shiznit is good info for me. LOL I'm even thinking about the jet pump resistance but I can turn them both by hand without much trouble. I still like the RFIs and all skis have issues that aren't easy to find at times. Touchdowns everyone... help is appreciated.
