I have the 98 sportster with the twin 717 85hp engines. The right motor runs great at full throttle (around 7000rpm) and never has a problem. The left engine, usually runs good for a min or so, at around 7000rpm, then falls to 5000, then revs back up to around 7, then back to 5, and does this for a while until it finally runs around 5000 rpm, no matter how far you push the throttle, even all the way up... if you pull the choke a little while it's doing this, it will rev up to 7000 and run good again for a min or so. Is something wrong with the carb? does it need to be rebuilt? or could this just be a screw setting on the carb? what do you guys recommend doing.
the boat runs fine all day long if I run both engines at around 5000 rpm.
