PJ Moran
Hi, all.
Like several others have, I just experienced the failure of the plastic nut that retains the back end of the reverse gate cable. The PWC was stuck in "sorta reverse". Upon inspection, I found the nut had broken and the cable had slid rearward. It looked like I would have to remove lots of stuff back there in order to get to the remnants of the nut. And, I feared I would have to remove the cable entirely, as well.
As others figured out, I was able to use external snap ring pliers to get the broken piece out (I came up with this trick years ago - I've removed many a broken fitting). But, I had to pull the cable forward in able to get the pliers in there. I did not pull the housing all the way through because it would be hell to fish it back through. To facilitate that, I had to remove the "large boot" and the "small boot" and the screw-on eyelet at the end (which has to be removed to get the boots off). In order to get the slack I needed to push the cable in, I unhooked it at the control lever up front. I also removed the retainer up there.
I was able to get the "stub" out without removing anything but those cable parts. Not the deflector; not the impeller housing; nothing else. I was actually surprised by that.
I ordered a replacement nut from the SeaDoo parts store here. However, researching this after the fact revealed that there are superior aftermarket nuts available. Some are aluminum. Some are brass. Most are cheaper than the plastic SeaDoo part.
So, I have a question, which of the aftermarket nuts is the best? It seems to me one should go with brass because aluminum can corrode and gall. But, it looks like there are multiple versions of brass nuts available. No one wants do to this job twice, so I want to get the best part for the job.
