j_cruton
Need a second opinion here guys. So the bolts connecting the reverse rod from bucket to bucket keep breaking. It's a pretty big issue because when I'm going 30-40mph it will all of a sudden drop one bucket and basically almost sub my boat which is not what I want to do ever. It seems like there is a ton of play in the buckets when they're in any gear so I'm not sure if it has something to do with my lever attaching to reverse cable, as you can see from the video.
Sometimes the shifter will want to go into reverse randomly when at speed 15mph+ and when at slower speeds 0-10mph it will drop into reverse. It seems like the play could be the case with this.
And while I'm at it may as well bring up another issue the boat doesn't want to turn starboard. When trying to turn port its fine but when turning starboard the boat banks but doesn't pull the water like it feels when turn port. I think this could be a jet alignment issue but I'm just bouncing ideas around.
First time boat owner so definitely a learning process. Thank you for any input guys!
