digerata
At the end of the day of my last trip out, I couldn't get the shifter out of forward in order to start the boat. It had stuck before, so like an idiot, I gave it a good yank and all sorts of bad happened. :0
I bent the end of the starboard reverse cable. On the port reverse cable, the threaded end sheared off completely. The reverse links were also bent. The port throttle cable support was also bent leaving that engine in 1/4 throttle at idle position...
Okay, expensive mistake!
I just can't get over a single cable that costs $150+. Gah! Can you believe that little pivot bracket for the cables is $65 oem??
So the bent parts I have straightened out and the bent reverse cable is working fairly well. The question I have is, can I cut new threads farther up on the cable that broke? Has anyone tried this before?
I'm pretty sure the thread is 10#32 NF. The matching die I used tonight just couldn't get started. (used cutting oil and everything) It even appeared to wear out the die. Assuming this is stainless steel, then? I haven't cut new threads all that often, but never had a problem before... Any ideas?
Thanks!
-Mike
Thanks!
-Mike
