We recently pulled all 4 rave valves to clean them on our recently purchased 1997 Sea Doo Challenger 1800 (twin 787s) two find that a valve on each motor had broken--both corners on the blade ends. On the one, we found the piece in the slot and it looked like a recent breakage. On the other, the piece was gone and there is evidence that the break is older--there is carbon covering the broken surface. There is quite a bit of carbon buildup and we were getting oil out of the raves prior to pulling them.
We have been told that the broken piece more than likely went out the exhaust into the water box. We have not noticed any significant loss in power or RPM.
We are going to replace all 4 valves and install new gaskets, seals, etc. Should we purchase the OEM valves or the SBT? There is a price difference of about $50 per valve, OEM obviously being the more expensive.
Also, should we attempt to clean the slot where the valves slide down into? Should we pull the top half of the motor? Again, we have no loss in compression and the boat was running with plenty of power/rpm prior to pulling the valves.
Thanks for any help you can give. In the future, we plan on pulling and cleaning our RAVEs twice a summer.
