bigJake
I melted a plastic rave exhaust valve in 2 hours use (not the first one to melt, usually just the threads disappear) I have new o-rings installed so that's not the issue. There seems to be excessive play if I wiggle the rave so I'm assuming the housing and/or valve stem are worn but every site I've checked, OEM housings are not available. All I'm finding are Chinese aftermarket from Titan and JSP. I posted previously if anyone had tried the Titan and replies were that the metal was too soft and they wore out quickly. Anyone know of GOOD aftermarket or where to find OEM? Offhore Marine lists one for $50 but does not specify the brand. UPDATE: OffShore Marine tells me their housing is made by WSM. I have no idea if that means it is any good or not?
I only put on a few hours a year so the cheap $25 ones might be adequate and just replace as necessary vs $100 for OEM.
I also plan to switch to the aluminum caps.
Also, wondering if there is a specific size bolt or something that should fit snugly in the housing hole that I can use to verify if the housing is really worn or if it's just the valve stem?
I've never put anything around the base of the bellows, I just noticed the parts diagram calls for Dow Corning 111. Can I just use Super Lube Synthetic Grease?
