H haroldpaul New Member Jun 28, 2014 #1 just replaced spark plus on 2011 gts does same thing.runs rough from 1900 to 2150.from 1600 to 1850 runs smooth& from 2200 & up fine
red2blue New Member Jun 28, 2014 #2 haroldpaul said: just replaced spark plus on 2011 gts does same thing.runs rough from 1900 to 2150.from 1600 to 1850 runs smooth& from 2200 & up fine Click to expand... Mine idles between 1850-2100...so..... You made sure to remove the cap from the plugs?...threads on top only? Fresh gas? Were your latest numbers in the water or on a trailer?
AircraftDoc Active Member Jun 30, 2014 #5 New spark plugs can be bad if the kid at the counter drops them. Old fuel?? The rough running engine at 1,900 could be a impeller to engine imbalance. Check the leading edges of the impeller. Then the maybe the cover for water and re-grease it.
