Replace impeller?
mejim707
I’ve finished replacing my wear ring. After removing the impeller I see dings in the impeller. I’ve filed down the high parts.
The fit is real close and I’m thrilled about that! But the blades don’t perfectly match the contour through the curve. Around the mid area of the blade curve it’s further out from the start of the curve and end. This may not be an issue, but I’m OCD and need confirmation.
Should I replace the impeller? If so what do you suggest?
Thanks!
BC3AEBB8-6A70-4186-954A-64345DD5C00F.jpeg59EF31E3-FA80-4170-B188-07F6DC90664A.jpegF8913881-2ABA-416C-AFAA-8E738F8414FF.jpeg5EAD930C-327B-4927-8490-E28B89984C4D.jpeg
