Magnolia00
First of all hello everyone...new to the forums and this is my first post but been here looking around for almost a year. I'm sure you guys will be able to help. My issue is I bought a 2003 Sea Doo GTI last year which turned out to be used in salt water and wasn't properly taken care of (I'm assuming) so now one of the four plugs on the tuned pipe assembly is leaking. At this point I'm just trying to get the pipe removed so I can fine someone to repair it. I've taken off a total of 3 bolts and the one nut that connect it to exhaust manifold as well as one bolt on the lower end of the curved pipe that (I believe) connects it to the engine. I have also loosened the clamp closest to the tuned pipe located at the bottom which in turn connects to the exhaust cone. My question...is there anything else that needs to be loosened as even though I've removed these parts I still can't get this baby to come off? Could it just be that some sealant was been applied where the gasket goes has hardened pretty good therefore making it hard to remove or could it be something else? Any one have any suggestions as to how you have removed it? Thanks everyone for any input you may provide. I've been looking around for a few days to see if anyone else had asked this before so I wouldn't post a dup question but can't seem to find my exact situation. Thanks.
