sydneygriffith
Moving from neutral to either Forward or reverse is very stiff so this weekend I decided to diagnose the problem. Upon disconnecting the cable from the reverse bucket it became clear the bucket is the problem. The cable moves fine but the bucket is stiff to move up and down when disconnected,
I am guessing the two bolts that hold the bucket are on too tight or need new bushings. However I cannot get that pin out that lock the bolts in place. The pins seem to go in from top to bottom and appear designed to keep the bucket bolts from loosing and falling off
Any ideas or suggestionson this repair?
