Removing old gasket material
Captain RonJon
I tried searching for this but couldn't come up with anything except to try a wire wheel, on a drill I presume. But there's gotta be a better way - so this is a very novice question but what's the best way to remove old gasket material? I would worry that a wire wheel would damage the mating surface.
Thanks!!
They make a gasket scraper, which is basically like a small metal wedge with a sharpened edge that works well. Many use a flat razor blade. A wire wheel works pretty good and unless you really dig in, it does not hurt the aluminum.
We use razor blades. Take them and lightly scrape the surface in a flicking motion. Do not dig at the material just lightly scrape
Ok, thank you gents - I can do that!
Do you have a good source for replacement gaskets you like?
Here's my method. I just flick back and forth or drag back and forth keeping the blade flat to the mating surface. Keep the power tools AWAY from the engines.
Yepp just a razor blade. Work slow and dont dig in. They make a gel gasket remover but it doesnt work too well. I have also use that orange sticker remover - Goof Off but the razor still works the best. 3M also has a gasket remover type sanding disk but I found that it still eats at the metal.
I've usually just used the gasket scraper first then come back with the razorblade, I've never had to bother with power tools, and before I lost access to my neighbors blast cabinet (bastard moved on me) I could get any left over specs of crap, and clean out the nooks and crannies pretty quickly with that.
I just borrowed a gasket scraper from a friend and I already have blades, so I will use them both! Drill and wire wheels make me nervous. I'll have to see if they make a bench top bead blasting cabinet - seems like many in here use them. Might be a worthy investment given the time it saves. I think so far I have spent more on tools and supplies than I have on parts!
