alright so i bought a 96 xp about a month ago now, and at the time the guy i got it from said the injector simply was not hooked up, but everything was there if i wanted to. i have just been pre-mixing my gas, because i honestly prefer it that way and i don't know if the pump works. i had been talking to someone else about it and they said i needed to use a block off kit to properly remove the pump, because if not it could ruin my motor. mine right now just has the hose from the tank to the pump removed and blocked. i was told that the pump lubricates itself using that, so if i have it blocked off it won't and burn up. what is the truth behind this?
