I want to replace my gray fuel lines and replace the float in my fuel baffle. I cannot do either one unless I can get the baffle out of the tank and I don't want to mix up the lines from petcock to baffle, and you need two hands to work on removing and reapplying hose clamps, etc. It's easier and mistake proof to do this under direct vision with everything removed.
I was told to slide the fuel tank forward to remove the baffle but the baffle is too tall, not enough headroom under the hull, to come out, even if I twist the tank as much as possible. A waste of 3 hours of time. Do I have to remove the steering head, and is it just the 4 bolts mounting it to the top of the hull, or is there more involved, like removing cables and wiring to get this off? Does the tank have to be forward when the steering head comes off or if I put it back, will the baffle be able to be raised enough to be removed with the tank in it's normal position?
The engineers who designed this had to be idiots the way this is put together so you can't service anything. It's probably easier to pull the engine out and then remove the fuel tank than to take everything apart under the hull. Hopefully the reassembly will go faster than the dismantling to get the friggin baffle out.
Any help would be appreciated, thanks in advance.
