busterthejetboater
Hi All
I want to remove the jet drive from the boat. I have removed the power head (in process of overhauling it) and also removed the qty 4 nuts holding the drive hsg cover.
The problem is that I can not remove the housing. I have tried various things over a period of 2 weeks but without luck. I have soaked the cover in WD40 (around gasket and protruding studs), applied heat to cover with heat gun, hitting with dead blow hammer, tried wedging in a forged wedge and or pry bar - tricky as I do not want to damage fiberglass or castings.
My last resort was to apply downwards pull on the jet housing by using 2 ratchet straps - 1 on front and 1 at the rear - pulling on the trailer cross members. I have applied heat, WD40, hitting with soft blow hammer but still no luck.
Anybody that has had a similar problem or just any old suggestion will be greatly appreciated.
Thanks
Thanks
