joesympatico
Hi group I have the typical problem with no power on my 98 XP Starts and idles ok but as soon as you give it throttle it dies. It seems to be just running on one cylinder as I pulled one plug wire off as it was running and it made no difference one plug. So I checked for spark and it was ok. So I am assuming its a clogged filter in the carb( yes I have the grey fuel lines) and I did clean the filter under the hood.
I am trying to get at the carbs to clean the filters but I am having trouble getting the exhaust chamber off.( the big black sucker) The problem I'm having is trying to get the bottom bolt off , it seems impossible to get a wrench or socket in that small space, any suggestion on how to get at that bolt or is unbolting the manifold the way to go.
thanks guys:ack:
thanks guys:ack:
