Remove engine cover/ splash guard for compression test
BoaterKanuckBoater
Hi guys, I have done compression test on cars, looking at a 2007 seadoo challenger today. Is engine cover similar to cars where it just pulls out or is anchored with nuts and bolts?
I would need that off before I can access spark plugs.
What else should I look for, doing a water test and checking compression.
Attached is a picture of the black cover I would need off before accessing spark plugs.
Blow the plug holes out before you remove the plugs, you will need a 16mm plug socket, magnetic preferably. The spark plug thread is a 12mm , if you don't have that adaptor then you need to get one or buy the tester with one in it.
