check the collar in front of the carbon boot and pull the silver collar toward the aft/rear of the ski and see if there is a lock ring inside it, I removed my engine with the drive shaft still in, I just picked the motor up and then moved it forward about 2 in's or so and the shaft will come right out, then you can play with getting it out. The manual should show you step by step to remove it.
