Rebuilt Crank or Rebuilt Engine? What would you do?
randomguy
So I've got a Rotax 657 (that's apparently already been rebuilt, pistons say 050) with a bent con rod. I've got the engine out and torn down, I'm just waiting on the PTO spline tool to get the rear flywheel off, then I can totally open her up and have my way.
I'm weighing my options on what to do now as the boat ain't worth much, but I hate to just scrap it out. So I see my options like this:
1. Get a rebuilt crank. Crank for $225 from SBT, get a bunch of misc gaskets and seals, need to replace rings as I bent one removing it. The way I see it, this will cost me about $350-$375 plus s/h. Obviously there's a lot of time involved as well, but this would be my first engine rebuild and the cool factor of doing it myself would have value as well.
2. Get a rebuilt "standard" engine from SBT. $595 + s/h, maybe I could sell the core to get some $ back. Also need an installation seal kit, break in oil, oil block off plate, and some other odds and ends. I see this as being $675 or so + s/h. Honestly, I wouldn't really be looking forward to the reinstallation of the oil injection pump while in the hull.
What other factors am I not thinking of? I have a decent level of confidence that I could install the crank and reassemble, at least with this forum and the shop manual to hold my hand anyway. I'm an engineer by day and I work at a machine shop, so I've got access to fine measuring equipment and I've seem to have all the tools needed except for a couple specialized ones. Are there difficulties that I'm not thinking of that I should factor in? Other advice?
Also, I'm concerned about moving forward without knowing the true root cause of the problem, but I'll be posting a separate thread about that. What do you guys think?
And shipping is crazy I know to tx its 180 so say I bought me a 787 for my xp its 849 plus 180 round shipping so u get the motor and send core back. I'm not sure on cranks. Might want to call them
I assume you have to send your crank back just like you have to do for whole engines (and for top ends, as i did last year). SBT remanufactures ski parts... meaning they take old parts, fix them up, and sell them to other people, who in turn send them back their broken parts so SBT can fix them and continue the endless cycle
If you don't send your cor back... that engine will wind up costing you +$3000.
It's up to you on what to do... but if it was my engine... when the lower half needs work... I would just rebuild the entire engine.
