Took the 1999 GTX RFI out today and was dragging the church youth around and started losing rpm's. Usually pulls 6700+ but after towing for quite a bit could only get 5200 rpm's. Thought at first it might be the rave valves but when I got home decided to do a compression test and cylinder #1 was 120psi and #2 was 150. My question is can I do a top end kit without tearing apart the whole motor? Are the sleeves in the jugs replaceable and are they pressed in? Can the top end be done in the ski or does the engine need to be pulled? Thanks for any help, we love the ski and have had a great time with it and besides the compression issue it's in great shape and we want to keep it.
Thanks
Ted
Thanks
Ted
