I am replacing the seals on my steering cable (rear hull) and want to know if anyone bought either the newer white Seadoo nut or one of the aftermarket aluminum nuts that fit the long removal tool so that the pump does not have to be removed. My pumps are installed with the right stuff as a sealant so they are a real bear to remove and I don't need to touch the wear rings. Original nuts were 15/16 (tool made for that) but sounds like all the aftermarket nuts are 1"...not sure if the newer white Seadoo one is still 15/16.
