Biffitis
So I've had my 97 Challenger (single 787) out a few times so far this year and after a winter of tweaking and tuning (thanks to this forum) it's running great. I have noticed though after a few hours on the water that both RAVE Valves are showing a small amount of black around them. Now they shouldn't be leaking since I rebuilt both of them recently with new pistons (the plastic disc), O rings, gaskets etc. I did NOT replace the bellows since I couldn't see any signs of wear & tear.
Is it normal for them to leak exhaust a little? Or, perhaps the garter spring that holds the bellows to the piston is weak and allowing some exh. pressure by. It's not a huge issue, but I've spent several hours cleaning the engine & bay and would like to keep it clean.
Suggestions?
Suggestions?
