RAVE= Rotax Adustable Variable Exhaust
Kind of hard to explain, but Ill give it a shot
When you hit the throttle flipper, the harder you hit it, the more the RAVEs will open. They are on the carb, so one for every piston. If they are not working right, then they wont open or close when they should, causing the ski to run bad or most likely not run at all. If yours are not working I would immeadiatly fix them or if you cant then take the ski to the dealer.
Pretty vague description, but thats all I got :hat:
