Bonmotwang
My 97SPX is still running strong!
At end of last season I notice some black oil leaking around one of the RAVE valve.
I opened the top and took a look. Everything looked ok except the black oil. Valve also moves up and down smoothly. I have temperature sensors installed on both valves, they were both normal. So I didn’t bother it fix it for the rest of season.
Now it is the time to fix it.
I took that valve of the engine, O-ring, spring, bellow and the valve all look fine. The only thing I noticed is when I unscrew the plastic top (10mm thread?) it was not tight.
Probably just clean everything and put it back and keep monitoring?
