Rave Valve Melted
FULL-THROTTLE
Hello all,
I put in a new SBT 787 engine, put approx 15 hrs on it, on the last run I took a good look at both engines before I put the boat in the water and no problems, after I got it home I took a look at the engines and the plastic cap on one of the RAVE valves is melted, I pulled the cap off and the valve has considerable lateral play, 3 times as much as the other three????
This is an easy fix, but wanted to share the experience and ask for your feedback.
Whats you opinion on this?
Hey Full. Check the "o" rings for your RAVE valves. If these are bad it will allow the hot exhaust to pass through and heat up that plastic cap. :cheers:
