tomcat&family
Hey guys-
I thought that making a new thread for this topic would be best, since it is related to one thing in particular.
I was advised in my other thread to clean my RAVE valves. After the rain let up, I headed down the '99 GTX RFI that wasn't running as well as the other (lower RPMs, slightly lower speed, etc... see other thread for more detail). I got one of the RAVE valves disassembled, and here is what I found:
This was the back RAVE valve, and as you can see, it was extremely oily. Is that normal? I have never worked on one of these before, so I am not sure what to look for.
Here's what it looked like after I wiped it down:
I then used brake cleaner, a wire brush, and a wire wheel on a Dremel to clean the carbon up. As per the recommendation of someone else, I sanded it with some fine sandpaper as well. Here's the result:
Okay. Now should I be worried about all of that oil? How does everything look? I also cleaned out the inside of the slot where the valve goes in, but I have yet to reassemble anything. I heard thunder, so I decided to get the boat covered up before it started raining again. By the pictures, do you think it is safe for me to reassemble the valve and proceed to cleaning the second one up? What about the third RAVE valve in the back? Should I clean that one too?
Thanks,
-Tom & Family.
Thanks,
-Tom & Family.
