Once you get the feel of where the Raves open and are happy with it, there will be no adjustment needed any more. The adjustments do not give more power or rpm's it just moves the "power band" (for lack of a better term) higher or lower.
From the manual.
The RAVE valve does not allow an engine to make
higher peak horsepower than an engine not so
equipped, it can make moving the peak higher
practical because of its effect on the rest of the
power curve.
If the RAVE valve opens too late, the engine will
bog or hesitate momentarily as the RPM increases.
Full peak performance is still available.
From a functional point of view. It is better to have
the valve open a bit early than a bit late.
