gioakjoe
So I have replaced the plugs changed filters emptied my gas tank, used new gas, and some times ruining the boat on the lake it just dies randomly. It always starts right back up with no problems, does it at all speed and rpm levels and some times it doesn't do it. Some days I go out and it gets me like 3 times in a row and other days ill be out all day and never happens. I thought I got past it caz it happened last year and then went like 5 outings with out it happening.
My main thinking is there is a short, I checked all the main power cables to make sure they are tight and not corroded. The battery is new and my smart craft meter says battery is always above 12v when on. It also doesn't give me any beeps or warnings when the boat shuts off.
My only guess is that my kill switch is getting some bleed over voltage maybe causing it to cut the engine for a second, if I cut this cable would this prevent the kill switch or will this prevent the engine from starting. I don't know if the engine is looking for voltage or the absence of voltage?
any ideas?
any ideas?
