Yes, lack of oil will kill a motor quickly. Also using the correct oil too is important.
Also air leaks could make a lean burn which is bad too.
RE: loss of comp could be due to bad or loss of rings, hole in piston, etc.
The members here with more knowledge of the Merc engines will answer shortly.
