i was out on the lake with a seadoo with a 787 engine that i just got well the fuel gauge doesn't work like every other seadoo and the little red light was on where it said fuel/oil warn. i thought it was just the low fuel from the bad sending unit but turns out that the oil line popped off and drained the entire oil tank into the hull. i ran it for maybe 30 minutes at low speed since i was pulling a kid in a tube never got over 4000 rpm. i thought this would destroy the engine but not having oil usually takes out the piston rings first so i did a compression test and i am still getting 150 psi in both pistons and engine runs great. Any one else ever have this happen? the engine is also a sbt rebuild..not sure how it could function that long without taking out a ring or at least losing some compression
jeff
jeff
