shattered00
Hello All,
I have a few questions that run the gamut. I am attempting to prepare my 95 and two 96 XPs while the engines are rebuilt. Pics are at the bottom.
1) In the 95, there is a a strap that holds the exhaust down. I am not sure what happened, but the screw (fully in tact) does not line up with anything. There is a hole (it appears something metal is in it like a part of a broken screw possibly?) where I think the screw on the strap is supposed to go, but it doesn't line up and even if it did, I don't think it is supposed to screw into the pre-existing hole since there is something in it. I could try and screw a new hole in one of the indentions on the strap that is closer in, however, I am not sure how safe it is to then screw it into the hull creating a new hole. Any suggestions or is it not a super big deal if the exhaust is not held down by the strap? I bet it could be a big deal, but just asking.
TLDR: Help with figuring out exhaust strap screw that doesn't line up
2) In the 96s, I opened up the VTS motor box and one is horrendous while the other shows signs of some corrosion. I am going to play it safe and replace both of them as I failed to test either of them before I took everything apart. It appears the gasket for the VTS box is shot on each (bent and overall crammed awkwardly in the boxes). I will be replacing the gaskets. My question is as follows: Can anyone tell me if this VTS boot is the OEM one which I have read is prone to leak and are any of the newer model ones good to go to replace it?
TLDR: Please look at the VTS boot and tell me if it is OEM or if there is something else I need to replace to prevent a future VTS motor leakage incident.
3) The two 96 seats are shot. They have tears and deep gouges in them and the foam has been exposed to years of sun and water based on info I gathered from the previous owner. The foam is not squishy like a soft sponge anymore in the parts that are exposed and there is a mild odor in those areas. Are these seats salvageable in terms of being reupholstered or should I look for seats elsewhere?
TLDR: Can I have these seats fixed for a reasonable price or are they beyond repair?
4) One of the 96s has a few chips in the gelcote and some spider web cracks. Can I just buy a gelcote kit and fill the chips in and run a light coat over the spider web cracks followed by a buff job? I am trying to aim for someone not being able to tell that there were ever chips or cracks.
5) I pulled the OEM foot mats up. I failed to use the drill as recommended in some threads and instead used a chisel and hammer method where the chisel is placed under the mat and the head of the rivet is knocked off. This resulted in several rivet holes that had surrounding gelcote damage in the form of chips. I plan to lay down Hydro Turf after buffing everything. My question is as follows: How bad did I screw this up and would it help support the structure if I filled the holes/damaged portions in with marine epoxy? I figure the new mats will seal everything from water, but I am concerned with increased chipping caused by my original damage.
TLDR: Should I use marine epoxy to fill in the damaged rivet holes in the footwell mats area?
This is an example of what I am talking about when I say "damaged rivet hole."
Thank you for all of your advice.
