Hoping someone can help Or offer some guidance. I recently picked up a 2001 rx injected with the 947 engine. previous owner told me he had recently done a top end and there was low compression in one cylinder after what he thought was a oil issue. I ran a compression test and found no compression on both cylinders. I removed the head and checked the piston and rings. They piston fine from the top and the walls were not scored, and the rings were all intact through the rave holes. what’s your opinion? Gasket, rave valves or something completely different. It turns over fine and when i cranked it with the plugs remove you could see fuel being pushed through the hole. I have worked on two strokes for many years, but never rebuilt one. But i am going to try If that’s what it needs.
