coletrain777
So...
I finally decided to pull the pumps on my 1800 Sportster and here is what I found:
Now for questions:
1. The clearance on the wear rings is very acceptable (well below the limit), but there are a few spots on each ring at the outside where there are noticeable gouges/chunks. The rest of the rings look pretty good, but I assume that they should be replaced b/c of the damage???
2. The working edges of the impellers look brand new, not a scratch on them, but as you can see the flat edge on each one is a little banged up. I am guessing that isn't a problem as the flat section shouldn't do have much of any effect on propulsion... is this correct? I have no idea how this would have happened unless they came like this from the factory.
3. What is the cone type seal that is in the end of each pump that the driveshaft slides into? One of these seals was folded back on it's lip, should I replace it? Would this seal being boogered up have any effect on the drive of the pumps?
4. Finally, as you can see in the pics the driveshaft cover on my left driveshaft is broken up, and the rights one is almost completely gone. How essential are these? I just can't see any real use for them, but if they are needed I will replace them while I am in there.
Now for questions:
