SeaDooGood
I have a 97 XP and I've been doing some required maintenance and one thing I noticed was that the oil in the tank appears to be a blue/green color which I was told is most like regular TC-W3 oil which is the wrong kind to use (even the guy I bought it from said to use TC-W3 when I asked him what kind of oil he had been using). I'm not mechanically inclined in the least bit and want to try and swap out the oil as simple as possible. My question is...could I most likely get away with just using a hand pump and pumping all the oil out of the tank and then just filling it up with the correct XPS synthetic oil that is required? I was thinking about even clamping off the hose before and after the filter and putting a new filter on and then filling the tank back up with the correct oil. Do y'all think the little amount on the hoses will cause a problem? I'm kind of nervous to remove all of these hoses and doing something wrong like getting air in the line and want to make is as easy as possible. Thanks in advance!
