marshall1322
I have a 06 sportster(155hp 4 tec) and installed a Briggs&Stratton digital
display Maintenance minder per instuctions....one wire wraps 4 times around plug wire and the other to ground.I ran the boat about 1hr but the meter shows 0.3hrs ?Is this because it is a 3 cyl engine and I need to multiply reading by 3? Is this meter for single cyl. only? below is the info on product....Thank if you can help.
Engine Applications
The MAINTENANCE MINDER can be used on any lawn mower type engines. The only limitation is the spark firing frequency must be greater than or equal to 10Hz. As most engines are operating at 20 or 40 spark firings per second, compatibility is not a problem. Easy Hookup
Engine Applications
