97 Challenger 1800 - twin 787s - new to me, and lots of restoration ongoing.
I show 210 psi in both cyl. (too high)
Squish is 0.090 (too large)
if I put an additional 0.030-0.040 base gasket ... won't compression increase?
am I missing something?
Thanks mikidymac,
so I am guessing the first thing to do is to pull the cylinders and get the squish in spec.... Correct?
if I had 090 and I see a 5 dot base gasket, should I get a 3 or 4 dot gasket?
If it was me I would pull the head and see if it looks like it was machined. There is no way a 5 hole gasket should be 210 psi. Are you sure the gauge is correct?
I believe the gauge is correct my other engine is showing 145 / 148 psi.
the compression issue may have been oil getting in . not much in cylinder but there was in the crankcase.
I did tear the top end apart, head looks good. I have another head from a spare.
measured the squish with each head (AND NO base gasket) = 067-071" with no gasket ????
can I go with no gasket???
or ???
