Faken
Hi guys,
I feel like we're so close to finally having a working boat! The engine is in and we're doing some VERY careful diagnostics to make sure everything is working, especially the cooling system. So just a couple of questions my brother and I had:
1. The hose with the braided covering in this photo, is it normal that this hose gets hot before any of the other cooling lines? We run the engine for maybe a minute and this line starts getting quite hot... you can still touch it, but it's definitely getting hot where the rest of the engine is cold. It runs on top of the compressor and connects to the left fuel rail when looking towards the back standing in front of the engine.
2. In regards to the cooling system for the exhaust, we have the water hose connected to the cooling intake and we're running water through the system. There is a hose that connects to a T connector and then separate hoses go from the T connector to the exhaust on each side. Is water supposed to come out of each end with equal pressure or does it depend on the angle of the boat? We noticed that depending on how the boats sits left to right, water will only flow to one side. Maybe this is due to lack of pressure because the engine isn't actually running and it's just hose pressure?
Thanks for your time guys, we're soooo close!!!
Dan
Dan
