maddagascar
Hello all, new to boats (Seadoo) and the seadoo forum. I recently purchased a Seadoo Speedster 200 and love it. I do have a few questions as I am definitely new to all of this. I tried searching, but no results.
1. The second time I took the boat out, the right engine (engine 2) was at a super high idle. I have two 155hp engines. Engine 1 on the left was at a steady cold start idle at around 2500ish rpm if i recall correctly. Engine 2 was at 5-6k rpm idle. I knew that was waaaay too high. I shut it off and started it back up, then it went to 7k, turned both engines off and it went back to 5k. I got out of the no wake zone and continued on slowly. Eventually, prob 10-15 mins in, both engines were pretty well matched at where they should be and I didn't experience any more high idle. Start ups have been flawless with ease, and she ran strong all day. Just curious if that is normal or if it's something I should look into.
2. Previous owner stated plugs were changed and was winterized accordingly. I'm not sure if I should bring it in for a tune up, but am wondering what should that entail if I do? I want to keep her running strong. I would do all the maintenance myself, but I really don't know where to start. I was going to have the dealer hook up their computer to it and see if any readings were off, check compression, etc...
So far, those are the main things. I have a Gaffrig Performance depth finder but it doesn't seem to work. Just beeps. I don't even know where the transducer is located unfortunately.
It also came with a Bimini top, but it is very low. I realized you can get different sizes and original owner must have wanted it lower for more shade. It's just really hard to get from the swim decl to the seats as you have to kind of limbo underneath the rear portion. It completely blocks my view as the driver to anyone behind me. It doesn't seem to be adjustable. I have a wake tower, so the top will only be as high with it open, while towing a tube/wakeboard. Maybe someone can share pics/dimensions with a top open and a tower installed?
Anyone have any recommendations on beach spikes? I have seen Sand Spikes some that are like $50, but I bet there are cheaper alternatives unless those are something you guys recommend.
I have plenty more questions, but those seemed to be at the top of the list.
Thanks again for all the help. Looking forward to a great season.
